grease fittings on Woods L306 mower - problems
cdon_FL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdon_FL Quote  Post ReplyReply Direct Link To This Post Topic: grease fittings on Woods L306 mower - problems
    Posted: 26 Jun 2019 at 10:41am
Is there a trick to greasing the 3 spindles on my Woods L306 mower deck?
the zerk in each of the spindles is very low down on the deck.  Not enough room for the tip of my grease gun to latch on for 2 of the 3.
I can get grease in one of the 3, but the cup (seal or bearing cap I assume) pops up under the pressure of the grease going in.
Any ideas on this topic ?
Chris in NE Florida
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 12:42pm
I agree it's a tight fit, but I can usually get on all three zerks on mine.  Make sure you've removed as much grass/dirt/old grease as you can from around the zerk.  You might have to try putting a different tip on your grease gun.  Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 12:46pm
If you are pushing the seal out by pumping grease in, you already have too much grease in there, STOP pumping.
 If your gun tip won't fit, get a different tip or a different gun, or replace the fitting with a 45 degree fitting so it points upward.
Image result for 1/4-28 grease fittings
Edited by CTuckerNWIL - 26 Jun 2019 at 12:49pm
tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbird Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 4:11pm
I put along grease fitting on my woods mower no problem to get grease in
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 5:56pm
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 9:13pm
I agree with Dave....get one of these fittings for your grease gun and never look back...best gizmo since sliced bread
Ocharry
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2019 at 1:04pm
You can also install extensions that move the zerk away from the spindle. Check your local auto supply store.
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2019 at 1:25pm
I had the same problem on my deck, to remedy it, I moved all the pulleys up higher on the shaft to allow more clearance for the grease gun. Worked great, now no problem greasing them, but I don’t run the guards on my deck, don’t know if they would need spacers to clear the higher pulleys or not, never had the covers to try.
If this hadn’t worked I was going to add grease lines to each spindle and make a block to mount the lines, so that all would be greased from one location. Big trucks used to have plastic lines to all grease fittings and automatic grease assemblies to automatically grease the truck going down the road.   I bet those lines and fittings are still available.
Good luck.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2019 at 5:09pm
I think adding a manifold to one spot, and running lines would be REAL handy. https://www.remotegreaselines.com/
[TUBE]R2YBJS0dZ98[/TUBE]
Edited by CTuckerNWIL - 27 Jun 2019 at 5:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2019 at 5:33pm
Problem with manifolds is expense, and down time, if they quit workin.  I like to grease things, and hear the "puck" of old grease being spit out...Wink
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2019 at 6:39am
How about a (what I call) needle nose for the gun.  I use mine quite often to get into pesky places like small U Joints.  My needle nose is screwed onto a metal tube that screws into the out put end on the grease gun.  That way you can keep both hands on the gun and the pressure needed to keep the needle nose firmly into the center of the zerk.
