Firing problem
spencefarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Topic: Firing problem
    Posted: 03 Jun 2019 at 10:14am
I've got spark, compression, and fuel. Why can't I get it to fire?
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 10:19am
Timing?  Too much fuel?
Edited by HoughMade - 03 Jun 2019 at 10:20am
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 10:20am
It ran no problem before. Could timing have been knocked out with it just sitting here?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 10:28am
Generally, no.  How have you tested for spark and fuel?
1951 B
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 10:29am
Probly not but it is only things to check so it can be rule out.
I just had a no start and was not getting spark at the plugs with power at the points. Put new coil and condenser and still no spark at the plugs. a new distributor cap last spring. I wiped it out when changing the coil how ever on close inspection it had a green build up. I scraped it off and it fired right up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 10:31am
I have a little inline spark tester that I used to check for spark. And the carburetor is getting flooded trying to crank it for too long.
How best should I check the timing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 10:43am
Cold, non running or static timing on any four cycle engine is timed at TDC on the compression stroke at number one cylinder. Depending on what engine, you look for the TDC on the flywheel where the inspection hole is located. At that point if it has a distributor the rotor would need to be pointed to the number one wire terminal with the points (just)ready to open. On a magneto the impulse will snap just past TDC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 10:48am
Were it me, before I got too deep with the timing, I would widen out the gap on the inline tester (if it is one that will do that) and see if it will jump more than 1/8th (.125) of an inch.  If yours doesn't allow for adjustment the gap length, then put a length of wire in the coil wire or on a spark plug wire and see if it will jump that gap.  Sometimes some spark isn't enough spark, but if it will jump the 1/8th inch gap, weak spark probably isn't the problem.
Though I would add that a really good spark will jump over 1/4".
Edited by HoughMade - 03 Jun 2019 at 10:49am
1951 B
OldSchoolRecovery View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 11:00am
Put new plugs in before messing with the timing. Then, a little starting fluid to make sure you don't have a fuel issue. Then you have ruled two things out. Then a compression check. All within 10%, number dosen't matter. Then , maybe look at timing.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 11:20am
A spark at atmospheric pressure doesn't mean you will have a spark at 100 psi. I doubt it's the timing if it ran when you parked it. It could be moisture, wires, plugs. Cranking the engine shouldn't cause the carburetor to flood unless you are cranking it with the choke closed.
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 11:35am
Timing would be the last thing that wouldn't allow it to fire and run, if it is at all close.
Regarding timing, I do it a little different but, it's a very accurate way of setting timing.
When #1 is coming up on the compression stroke, stop the flywheel at the timing mark that the book or you want for timing. Set the point gap, to your specs, then put one of the ohmmeter wires to the points and ground the other side.
You then twist the distributor until the ohmmeter indicates a open circuit (points break) and lock the distributor down. You then have the exact timing, if the bushing in the distributor are good. You do it the same way with a mag. You can also use this system for checking total timing turn the flywheel to the total timing mark you want, then twist the rotor shaft, to advance the centrifugal weights and the ohmmeter should show a circuit break, if not, hold the advance and again twist the distributor until it breaks. I do the total advance and ignore the initial advance.
Edited by frnkeore - 03 Jun 2019 at 11:39am
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 11:38am
I'm wit' Old School there. Toss a set of plugs in it. (not champion, somebody elses) It'll probably fire right up. If it ran fine when last used, the timing isn't gonna change. I would think, its a oxidized set of points or an old set of plugs or both....
JaredC(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 11:44am
Charge the battery and then try. My CA does just what you are describing even down to the flooding carb.
Seems like a partially discharged battery will have enough juice to start turning over, sucking fuel, etc but not enough umpf to ignite the fuel.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2019 at 12:36pm
What are we working on?
I had a lawnmower once that the plug wouldn't give a spark under compression. New plug solved that after a lot of head scratching..... and help from an older experienced mechanic.................... Once I had a lawnmower that would act like it was flooding out after it got warmed up. Turned out a new key switch solved that because as the old switch heated up it built up resistance and then was losing ignition. Funny things can happen if when you think you have fuel, spark, and compression.
Wink
I am a Russian Bot
This page was generated in 0.073 seconds.
