Leak around thermostat housing
rodnil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Topic: Leak around thermostat housing
    Posted: 02 May 2019 at 9:34pm
I have an AC 200 that has had a slow leak at the thermostat housing. The anti-freeze ends up on the alternator causing it to be rebuilt. I had it rebuilt today and replaced the currant thermostat and gasket. The gasket was thick but the new one was thin. I did a very good job of removing all of the old gasket replaced the old thermostat and gasket with new of each . Started the engine and the leak was worse than ever before. After looking at it closer it appears to be a gap on the outside edges of the housing and the elbow going to the upper radiator hose. A thicker gasket is not the answer. Will gasket sealer work?  Anyone else have such a problem and if so how did yo fix it?  I'll check Agco tomorrow to see if any of the two parts are still available
57WD45FarmUse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 57WD45FarmUse Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2019 at 10:17pm
Hi there. Well ya got the surfaces nice and clean...    how’d ya remove old gasket? Ive seen this one fella get a lil to rough with his ole pocketknife
Ya could try permatex the right stuff. I’ve used it to seal up a cuple situations that are similar to what ya describe
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 5:26am
I was very careful removing the gasket. Someone before me may not have been as careful, thus the leaking before and the thicker gasket. I'm guessing the next step will be to replace the neck piece (hoping to get a true flat surface) that the radiator hose connects to, and maybe replacing the part which is bolted to the block  (again looking for a true flat surface). Finding these part will be my next step.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 5:59am
I'm thinking 1 or the other part isn't really,really flat and true so I'd use a wide flat bastard file and 'mill' the parts. With a good square edged file, you can 'mill' ( clean up) the lips( if there are any). I've done this before and usually see quite a difference around the mounting holes. Also if there is a lip, that goes into the housing, file it down as well.Maybe it's a tab 'tall' and preventing the housing from mating  totally flat.
The fact the original gasket was thick indicates they weren't using computer guided CNC machine when it was built !
mechanicmarty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mechanicmarty Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 6:28am
If you can check how true flat it is with a small straight edge to make sure it doesn’t have a warp in in. Also if the housing has bolt hole that go through it and threaded holes in the block look really closely for cracks. I had a Mack engine water pump with what I thought was a leaking gasket. Turned out the threaded holes in the pump housing had tiny cracks(barely visible) so each time we would tighten the pump on the housing it would leak. We replaced the housing and she was good to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 3:42pm
GOOD NEWS !!! I ordered a neck which sits down over the thermostat and is connected to the radiator hose. Thermostat and gasket back in place bolted the new neck in place started the engine NO LEAK, I let it run for a good 30 minutes and no leak.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 4:41pm
Sure is nice when you win one, yes?
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 7:49pm
You bet it is !
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 10:04pm
I had the same issue on  my 7000. the upper housing is cheap pot metal. I "machined" it flat and used JD gasket maker with a new gasket. I think they get over tightened, which bends the metal. holding now.
This page was generated in 0.143 seconds.
