Oil leaks WD-45
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: Oil leaks WD-45
    Posted: 23 Apr 2019 at 8:43pm
My WD-45 is leaking right where the transmission and rear axle housing meets, It's been doing it for the past 2 years (a few drops where it sits overnight after being used) and now its getting bad to where I am adding about a quart per time. I know the best thing to do would be spilt it there and do a proper seal/gasket, however I'm a bit pinched for time and was wondering if anyone had any ideas? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 8:49pm
Have you tried tighting the bolts? Six bolts + frame bolts.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 9:11pm
I have them as snug as I possibly can get them with a with a wrench
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 6:54am
I would look again at the hand clutch shaft seal.
