Harrow Bearing
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Topic: Harrow Bearing
    Posted: 23 Apr 2019 at 8:15pm
I have an old AC harrow that uses the bearing 70330133. My local bearing supplier can't cross reference the bearing. Does anyone know a source for the bearing. It has a 1 inch ID with an outer diameter of 3 inches and a width of roughly 2.5 inches.
I would prefer to keep it original, but I saw a post where someone put three bearings together in the  bearing holder to make a bearing. It sounds plausible. Has anyone done that before? What are the bearing numbers that you used? Even better does someone know a source for the 70330133 bearing?
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 5:48am
I use 2 BCA 88107A bearings press old ones out install new ones
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 6:13am
Those are called balpak bearings.
Look in the knowledgebase section. There is a topic about them.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 10:25am
I have several of those bearing used. Some dealers still have them new. (costly). 785-353-2392
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 1:20pm
BY costly, he means like $300-$400. No wonder sales were so low they were discontinued 10 years ago
