185 Bearing carrier
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 185 Bearing carrier
    Posted: 22 Apr 2019 at 9:26am
While taking the brakes off, I also removed the bearing carrier off the right side to put in a new seal and O ring.  I noticed this one has no lip for the back of the oil seal to mate to.  The left side had one and the ones on my D17 diesel had them.
Should I find one that has a lip?  IF not, how far do I knock in the new seal?  There is no place for it to stop.
Edited by DSeries4 - 22 Apr 2019 at 9:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 10:50am
Just get it flush/square on one side or the other, usually from the inside. Take notice..... you'd better have the axle square to the seal or you'll ding the seal when going together.
Edited by DrAllis - 22 Apr 2019 at 10:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 8:02pm
Thanks Doc!  I'll tackle it next weekend.  People might not say it enough, but your advice and wisdom are most certainly appreciated here!
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 9:08pm
DITTO !!!!
