7020 Transmission Vent
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Topic: 7020 Transmission Vent
    Posted: 19 Apr 2019 at 4:38pm
Where is the vent on a 7020 PS. Are there 2 vents? I have a leak that I CANNOT locate. I had many small leaks, most of which have been fixed, but I can still EASILY lose a 1/4 gal/hr. It was closer to 1 gal/hr, before I fixed the other leaks. Oil ends up on the rear tires sometimes. Sometimes not.  Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2019 at 9:13pm
Is your fill tube loose where you check transmission oil? They break off where they enter range transmission housing and also get loose.       MACK
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2019 at 11:06pm
Thank you very much sir. The tube certainly wasn't loose, but there's a crack about 3/4" long in the 'flare' that bottoms on the top of the transmission. It may not be my whole problem, but it's certainly part of it. Thank you again.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 6:41pm
Just FYI, The vent is directly under a cab cross member about 4-5 inches forward of the oil fill tube and directly center left to right, it is a street ELL with wire mesh in it.......Or should be anyway.
Still in use:
