501 running gear wheel seal
kplew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kplew Quote  Post ReplyReply Direct Link To This Post Topic: 501 running gear wheel seal
    Posted: 19 Apr 2019 at 3:25pm
I have an old 501 running gear with 5 bolt hubs. The hubs have 0701 cast into them. I was able to get the old bearings out intact and have the numbers for them, but I can't find a number or anything on the wheel seals. Can anyone help me out with a part number for these seals?
Thanks
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2019 at 4:12pm
I looked at my A-C wagon spec sheet. There is nothing specifically called a "wheel seal". However there is a part simply called "seal". That part number=2013816. Hope that helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2019 at 4:35pm
Might have one
Post Options Post Options   Thanks (0) Thanks(0)   Quote kplew Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2019 at 4:49pm
Great, thanks. My Dad always called them "wheel seals" and after 60 years I guess I should know better but...
I actually need 4 seals, all 4 hubs need rebuilding.
I am looking for one 0701 hub, once I got everything apart I found one with the lug hole cracked out.
Thanks for the help.
