175 temp gauge |
cnafarms
Joined: 01 Jul 2011 Location: Mt. Airy, MD Points: 140 |
Topic: 175 temp gaugePosted: 14 Apr 2019 at 1:49pm |
So I ordered a set of gauges for my 175 diesel the amp, temp, and tach gauge. When the temp gauge came it has the temp probe that screws into the block like my D17 and D19 have and I know that the gauges for 175 are electric so my question is there anyway or anywhere on this tractor where I can screw this probe into so that the gauge will work or do I have to send it back and get the correct gauge.
orange-is-power
Posted: 14 Apr 2019 at 4:25pm |
You could remove the electrical sending unit that's in it now and replace it with the new mechanical one. It's on the RH side of the engine up front right behind the fan.
DrAllis
Posted: 14 Apr 2019 at 5:19pm |
I'm not sure that the old style mechanical gauge "bulb" will fit inside the Perkins engine temp sender location. Diameter of the threads too large and bulb too big/deep.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7723 |
Posted: 14 Apr 2019 at 9:31pm |
x2.
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 15 Apr 2019 at 9:40am |
I have install the mechanical ones in Perkins engines . need to drill and tap out where sender is now and use a adaptor .Did your gauge come with adaptor that the gauge screws into.
cnafarms
Posted: 15 Apr 2019 at 11:29am |
Yes it did come with an adapter. At the top of the motor where the top hose from radiator goes there’s a plug on mine that an Alan head fits. I took that plug out and the adapter screwed in perfectly to that. I believe there is plenty of space to screw the probe in. I
