Allis D-17 Electrical Issues
schroeder.389 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote schroeder.389 Quote  Post ReplyReply Direct Link To This Post Topic: Allis D-17 Electrical Issues
    Posted: 14 Apr 2019 at 10:19am
Working on restoring my grandpa's 1964 Allis D-17 Series IV Diesel tractor. We've had it through the shop to fix leaks and what not. At that time, they put a new voltage regulator and generator. We brought it home and dis-assembled it to get ready for blast and paint. After sand blasting and painting, we started re-assembly. The other day we went to hook up the battery and it sparked quite a bit and then a "sizzle" sound and we fried the main wiring harness. I figured the wires may have been brittle and maybe got hit a little with sand which made them bare and caused a short. Yesterday we installed a whole new wiring harness. Still no luck. Battery would still spark when trying to hook up the second terminal, which shouldn't happen. I'm very confused as to why this is happening. We found that the heater solenoid was getting power with the key off, so I installed the old key switch, hooked up battery, but tractor still would not start. I've also installed all new gauges for this tractor which are currently on in, not sure if there could be a problem there or something? This tractor is 12V positive ground with a generator and voltage regulator. Any help would be appreciated to try and get this thing running again! Thanks!
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 10:30am
There could be a problem in so many places. Disconnect everything. Starter, generator, regulator, manifold heater, lights, etc. With a good battery installed, start reconnecting everything, one item at a time. First touch the wire to its terminal and if there is no more than a tiny flicker of a spark, connect the wire. If you come to an item that makes a continuous spark, that might be where your problem is. The first thing I would suspect is the generator/regulator. FWIW I suspect that something was connected wrong when you put it back together after painting. Make certain that you are connecting things where they belong.
Edited by DougS - 14 Apr 2019 at 10:31am
polarbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 3:05pm
they are positive ground if they have a generator check if you use two battery's instead of one they are hooked properly in series
Edited by polarbear - 14 Apr 2019 at 3:07pm
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 5:00pm
Using two 6 volt batteries they would be in series to make 12 volts. If using two 12 volt batteries they need to be hooked up in parallel. Two 12s in series makes 24 volts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schroeder.389 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 5:38pm
we just have one 12V battery on the tractor.
cnafarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnafarms Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 7:56pm
Something similar has happened to me on both my D17 and D19. They are both positive to ground and I had them in the shop getting worked on. I’d almost say somewhere along the way someone hooked up the battery the normal way instead of positive to ground. Just my 2 cents though
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 9:24pm
The wiring diagram is on the last page of the owners manual.  Follow it and you will not have any problems.  Getting a spark when you attach the battery cable is an indication that you have something hooked up wrong.
Regarding your gauges, the D17 originally used manual gauges (not electric).  If you put electric gauges on, you are going to have more problems.  The wiring harness does not have any provisions for electric gauges.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schroeder.389 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 6:47am
Yes, this did happen.  I thought I was hooking the battery up correctly, but I had something mixed up and realized that I did have it hooked incorrectly.  So, I switched the cables and had it hooked up the correct way.  When we had it hooked up the correct way is when we fried the main wiring harness.  I've since replaced the harness, and no luck yet.  Do you remember where the problem was with your tractors when the battery was hooked up incorrectly?  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 8:18am
This is where it pays to buy quality parts. If you use high quality battery cables it is very difficult to hook the battery up wrong. The positive stud on a battery is larger than the negative stud. Quality cables take this into account and the battery cable terminals are sized for this. Cheap cables are made to fit either way. Try to fit the cables backward on a newer car and you'll not be able to tighten the positive cable on the negative stud. Also you'll not be able to even put the negative terminal on the positive stud unless you open it way up. I can't even open the negative terminal wide enough on my newer Ford. I just replaced that battery and I was barely able to put the negative terminal on the negative stud. Not that I'm wild about how it is designed in other ways.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 9:34am
Maybe they WERE pos ground. That doesn't mean his has to be. He said it was neg ground, which is totally possible
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 9:52am
Probably cooked the voltage regulator if you hooked something up wrong or backwards, and no way of rewiring will fix it. You can remove the cover and see if any contacts are stuck together.
 If you do get it wired up like you think it should be, don't crank the engine over till you flash the generator. There's no telling which way it will want to charge, if it does, and could make more of a mess than you have already.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schroeder.389 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 10:18am
How do you "flash" the generator?
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 10:34am
1951 B
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 10:46am
there is no rule or law that says a generator has to be positive ground, its all about how the generator is flashed before stating the engine.
i have both my d17d and d19d set up with negative grounds w/ generators and they work fine.
(As stated by Dseries4) Follow the wire schematic in the book and you should have no problems.
unless you have electric gauges.
Dan
Edited by Acdiesel - 16 Apr 2019 at 10:39am
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote schroeder.389 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 10:51am
Only electric gauge in the dash cluster is the "ammeter".
Edited by schroeder.389 - 15 Apr 2019 at 10:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnafarms Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 11:33am
Yes when mine were hooked up incorrectly I had to replace the voltage regulator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schroeder.389 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2019 at 7:03am
Hey guys, thanks for all the tips!  Had another set of eyes on this tractor last night and we identified two wires wrong on the key switch.  We also had a bad solenoid (even one of the new ones was bad that we had put on).  We had constant power to the heater, and needed to get that resolved!  We hooked everything back up, put some fuel and, and got the tractor running last night!  Such a good feeling!  Thanks for all the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2019 at 9:10am
  Thumbs Up Thumbs Up Momentary battery voltage to the field terminal of the generator is how you polarize or "flash" the generator. You don't polarize a voltage regulator, but the process can be done at the regulator terminals.
https://www.google.com/search?client=firefox-b-1-d&q=polarizing+a+gennerator+#kpvalbx=1
Edited by CTuckerNWIL - 16 Apr 2019 at 9:21am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2019 at 9:32am
Fundamentally there are several changes to be made when changing from positive ground electrical system to negative ground. While a positive ground alternator is theoretically possible easily virtually none exist because ever since 1964 or so SAE standards require only negative ground. Tractor makers were slow to follow that standard.
The ammeter connections need to be swapped so it reads right. Should show discharge with the engine not running and the lights on. Must show charge with the engine just started and the generator or alternator charging the battery. Some electric gauges for cooling system temperature and for fuel do not tolerate polarity change so have to be replaced with negative ground gauges and senders. If gasoline burning the ignition coil primary connections need to be swapped. Normally the primary connections are marked by a + and a -. For positive ground power goes to the - terminal and the + terminal goes to the points. For negative ground power goes to the + terminal and the - terminal goes to the points. Reversed coil connections won't absolutely prevent the engine starting but won't have a good spark for high speeds of heavy loads compared to the correct connections.
If the polarity change is accompanied by a change from 6 volts to 12 volts, gauges need to be replaced and the coil needs to either have a series resistor added to the power connection or changed to a 12 volt coil. 12 volt coils can have more primary turns or be a lower voltage coil with a suitable resistor inside the coil casing to make it work best at 12 volts.
If changing to a modern alternator the ammeter may need to be replaced with one having a current full scale at least as great as the alternator current rating.
Gerald J.
This page was generated in 0.150 seconds.
