C engine crank wick leaking |
Post Reply |
Author | ||
49WF
Bronze Level Joined: 06 Nov 2010 Location: S.D. Points: 118 |
Posted: 13 Apr 2019 at 4:01pm |
I put in a new ring gear,clutch, crank seal and rebuilt the oil pump. Assembled and ran, getting drips of oil out of bell housing. Tough to see in bellhousing. Appeared to be crank seal, new seal was felt. I ordered a cork seal and split again. My crank seal is dry, wick on crank is wet. Does anyone offer a new wick or can I eliminate the wick. Pilot bushing is not wet, it is new also.
More than I need
Sponsored Links | ||
49WF
I just thought about my comment on eliminating wick, didn't think that one through. How much is to much oil, it is already making a mess in bellhousing.
More than I need
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22818 |
Plug the crankshaft hole and use a sealed bearing if you don't want a bit of drip, every once in awhile. My WC is plugged with a sealed bearing.
chaskaduo
Orange Level Joined: 26 Nov 2016 Location: Twin Cities Points: 5203 |
Maybe Dick L would know the sealed bearing info for the B & C?
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4668 |
Charlie has it: Although it more than that simple. The C tractor only uses a pilot bushing which a dab of grease will last a long time. Plug the crank hole. Put a speediSleeve on the spiral groves on the crank. Use a seal housing and seal from the D10/12/14/15 tractors
CTuckerNWIL
It's been a while, but I may have had to bore the flywheel for that bearing, since it just had a bushing in it too.
Dick L
Orange Level Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
49WF
Is the wick hole pressurized? 1/8 pipe plug is to small. Called around for a pound in plug, no luck. If is not pressurized I might put in epoxy
More than I need
littlemarv
Orange Level Joined: 10 Jun 2013 Location: Wisconsin Points: 1829 |
If you want to plug the hole, just insert a tapered cork after pulling the wick out. Edited by littlemarv - 13 Apr 2019 at 7:54pm |
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
CTuckerNWIL
I drove to a machine shop every work for day and ran a lathe of some sorts most of the time. It didn't cost me anything, but a few minutes of my time after hours |
oldways
Orange Level Joined: 25 Apr 2013 Location: west Ky Points: 508 |
I put in a cork with a little Indian Head gasket shellack on my B and WC. If you want to replace the bronze pilot bushing and your closer to a case IH dealer it's the same as a Farmall C I believe. I'm 15 min from IH dealer and hour from an Agco dealer.
Edited by oldways - 13 Apr 2019 at 9:15pm |
Gerald J.
Orange Level Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
There might be some details in the shop manual:http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J. |
Dick L
Great! I own a custom mold shop started in 1997 that was once a three man shop as well but most people don't. Went down to a one man and myself when I bought these in 2002. Edited by Dick L - 14 Apr 2019 at 11:21am |
chaskaduo
Nice setup, I would live in there.
pcheffernan
Bronze Level Joined: 29 May 2023 Location: Indiana Points: 13 |
The wick is there to lubricate the pilot bushing. It is supposed to leak oil on it. Old school technology. They quit doing this many years ago, and now lubricate with grease. Probably not as effective but less of a mess.
Post Reply | |
