7020 Injection Pump |
Jack(Ky)
Topic: 7020 Injection PumpPosted: 12 Apr 2019 at 10:22am |
How can I tell if my pump has been turned up? It smokes a some but not a lot. I don't use all the horsepower and I would like have it turned down a little so it don't use so much fuel.
'59 D14 '68 170 Diesel '81 7020 40 All Crop
HD6GTOM
Posted: 12 Apr 2019 at 10:29am |
Smoke can be caused by using truck stop/ convience store diesel fuel instead of premium #2 diesel fuel. Your tractor was designed to use premium #2 fuel. Black smoke is unburned diesel fuel going up the stack.
Jack(Ky)
Posted: 12 Apr 2019 at 12:17pm |
L
Jack(Ky)
Posted: 12 Apr 2019 at 12:21pm |
MACK
Posted: 12 Apr 2019 at 9:22pm |
Be hard to tell unless you put it on test stand. I thought they all smoked. MACK
DrAllis
Posted: 12 Apr 2019 at 9:47pm |
If you take your 7020 tractor (rated at 120 HP max) and use it on a load that only requires the governor to demand 50 HP output from the engine, turning the fuel delivery down to produce a max of say 100 HP will show zero fuel savings on the same load. What you think you want to do really doesn't work like that.
Jack(Ky)
Posted: 13 Apr 2019 at 5:42am |
Thank you guys for the info!
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29821 |
Posted: 13 Apr 2019 at 6:23pm |
Put it on a dyno
Wink I am a Russian Bot |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3736 |
Posted: 13 Apr 2019 at 6:56pm |
You are packing 12,000 + pounds... lighten it up will save hp/fuel if it is weighted --- it is not an economy tractor as it takes hp to move that weight.
