Rebuilt 426 with a weird noise. |
AC 426 power
Topic: Rebuilt 426 with a weird noise.Posted: 11 Apr 2019 at 6:01pm |
Got my 7060 back together after rebuilding the engine, runs good, oil pressure is at 25 psi at idle, after a couple of hours of hard hard chisel plowing running John Deere break in oil, no blue smoke, starts better since I advanced the pump to 19 degrees, no noticeable blow by, but I'm hearing a whooshing sound or like air escaping somewhere when running at high RPM, primarily with the cab door and windows shut, doesn't seem to really lack power while pulling a 9 shank, remanufactured injectors, brand new turbo, all my connections look tight going from the air filter to the turbo, new intercooler boot, all new intercooler gaskets etc. Just an aggravating whooshing sound, any thoughts?
oldways
Posted: 11 Apr 2019 at 6:04pm |
Air in hydraulic a system ?
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2548 |
Posted: 11 Apr 2019 at 6:38pm |
Intercooler gasket problem??
AC 426 power
Posted: 11 Apr 2019 at 7:17pm |
AC 426 power
Posted: 11 Apr 2019 at 7:19pm |
MACK
Posted: 11 Apr 2019 at 9:30pm |
Have saw them blow at back of intercooler. Have been using some gasket sealer on them. MACK
ryan(IN)
Joined: 11 Sep 2009 Location: Bluffton,IN Points: 804 |
Posted: 11 Apr 2019 at 9:33pm |
Even if you think the rubber hose on the cross over seems tight check it. We had one come loose and make the noise you are describing.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1657 |
Posted: 12 Apr 2019 at 5:02pm |
Pressurize the air to air and as much of the hosing as you can. About 20 psi. You will find the leak if there is one. Sure sounds like it.
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 14 Apr 2019 at 8:18am |
Know a guy that had a JD engine rebuilt at the dealer. Had great power but had a noise under load. Took a while but we found the intake wasn't completely tight. Had to put shorter bolts in in a couple of places
AC 426 power
Posted: 14 Apr 2019 at 10:15am |
DrAllis
Posted: 14 Apr 2019 at 10:30am |
There are only so many places it can be leaking. The turbo hose to crossover pipe. The crossover pipe gasket to the intercooler. The 4-bolt cover on top of the intercooler. The intercooler to cylinder head gasket. That's it. This of course assumes all the plugs ( four) are in the intercooler body. This also assumes you don't have an exhaust leak, which you should see the soot from. It would take me less than an hour to drain the coolant in a clean 5 gallon pail and remove all the intercooler bolts and see what is going on. I always glue (3M brand 8001 yellow) the intercooler gasket to the intercooler and a thin layer of any RTV from the gasket to the cylinder head and recheck the bolt torque (engine COLD) after it has run a couple of days. You did glue the intercooler gasket to something, right ??
Edited by DrAllis - 14 Apr 2019 at 10:31am |
Lynn Marshall
Posted: 14 Apr 2019 at 10:52am |
You could hook up some air pressure to the ether port,but with open valves, I don't think that it will tell you much. The intercooler to the head gasket is most likely the problem if it is an intake leak.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5273 |
Posted: 14 Apr 2019 at 11:15am |
It's a lot of work, but to pressure check the intake tract, you can take the rocker assembly off, and put a plate in place of the crossover tube. My bet is either blown intake gasket, or a small plug left out on intake somewhere.
AC 426 power
Posted: 14 Apr 2019 at 1:29pm |
