D 10 hydraulic
TeamAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TeamAllis Quote  Post ReplyReply Direct Link To This Post Topic: D 10 hydraulic
    Posted: 08 Apr 2019 at 9:30pm
I have a D10 with 3 points hitch, the hydraulic cylinders will not collapse fully when not loaded. It is very difficult to hookup to a piece of equipment. I have to prize the lift arm down with a pry bar. Anyone seen the before? Appreciate any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 4:40am
What series is your D-10?
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 5:42am
I assume your tractor has the traction booster option.  If so try moving the control handle to see if the lift will come down.  If not, disconnect the tractor booster control valve from the torsion bar to see if you get any results.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 8:35pm
HellD12 -SN 1001o Team Allis     loosen the rear cap of the hyd lever and see if the spool is stuck???    [ Been a long time since]
