Gleaner 10bolt 5” spacers |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3801 |
Topic: Gleaner 10bolt 5” spacersPosted: 05 Apr 2019 at 8:11am |
Dished out my Gleaner’s Drive wheels to track differently, but need an additional 5” spacer on each wheel. Did Gleaner mfg such an item? It’s for a 78’ k2 that has the 10 bolt finals.
Edited by AC7060IL - 05 Apr 2019 at 8:40am |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9237 |
Posted: 05 Apr 2019 at 12:55pm |
I'm sure the answer is no.
What are you trying to accomplish? Get tires off the row? Good luck! Get an A2. It will track between the rows. |
soybreedingboy77
Posted: 08 Apr 2019 at 10:28pm |
I put some 9" spacers on my F2 10 years ago. Ordered them from Unverferth. Less than $1000 if I remember.
MACK
Posted: 09 Apr 2019 at 9:13pm |
Before you put spacers on, remove final drives, remove cotter pin through adjusting nut and axle, drill to 1/4 and drive roll pin through nut and axle. MACK
SteveM C/IL
Posted: 09 Apr 2019 at 9:36pm |
yeah. I didn't know about the shearing cotter pin deal till I had put mine back together .Yes it was the left side and yes the bin has had something like 2 ft added to right side.They did a good job. Looks factory.
