Wd clutch and brake pedal wear
tom51 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Topic: Wd clutch and brake pedal wear
    Posted: 04 Apr 2019 at 12:16pm
Long time lurker first time poster. Looking for information on repairing these pedals holes are wholuded out shaft is ok.Does anybody fix these with new bushings? Have gotten lots of great information from this great site. Thank you Wink
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2019 at 10:00pm
yes you can put a bushing in the clutch and one brake but you better look close at your shaft.
Albert
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 7:51am
I have repaired several of them. I have not found a shaft that was not worn.
Where in Wisconsin are you?
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 1:09pm
Thank you Alvin. Lonn, s.e. wi. have a daughter by you in otsego  next time I'm that way I'll look you up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 2:28pm
It doesn't get any better than this....
https://www.allischalmers.com/forum/f-s-wd-wd45-reconditioned-parts_topic148897.html
Yes, where in WI are you?  He'll be in Hutchison, MN this July and Union Grove, WI in August.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 4:19pm
That was the thread I was looking for. Thank you Ted. I live 20 miles west of Union Grove. See you there in September.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 7:46pm
New shaft is available from Steiner. It will be worn somewhat. Pedals have to be bushed at machine shop. Have to do both to get it all tight. Even a bit of shaft wear will let the pedal flop around a fair bit. Steiner shaft is very inexpensive.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 8:50pm
I take the shaft and pedals to my local fab shop.  They make a new shaft and put new bushings in the pedals.  Well worth the money.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 9:07pm
Thank you for the suggestions. Have a friend that does machine work I'm sure he can fix me up new bushings and shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2019 at 12:54pm
That brake and clutch shaft is $49 at steiner. I paid $200 to my machinist friend to make one. I'm not complaining it was not available at the time. Just the advantage of mass production. Part number is ACS2678.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2019 at 6:31pm
The shaft has special tapers. To do it like the original you would need to make a cutter. I have a new shaft on the shelf $35.00 plus the ride.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2019 at 11:03pm
Lon(MN) sent you a pm
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 8:43am
The shaft on my narrow front 45 was worn pretty bad. I welded it up and filed it back round. Worked good. Then got lucky and got some great pedals on E-bay.
This page was generated in 0.069 seconds.
