190xt progress |
ebowman
Joined: 06 Sep 2018 Location: Kirklin, IN Points: 161 |
Topic: 190xt progressPosted: 04 Apr 2019 at 9:38am |
Just wanted to share some pictures of what you all have made possible!!
![]() Just some of the machined parts. Awesome looking clutch (thanks Rick!!) ![]() New liners are in!! Only requires 2 orings!! On my next one I'll take sleeves to machine shop and get one cut in between the two! (Great idea MACK??, That would help if there is much eroding in the block) ![]() New pistons (Got some extra help on the weekend.. guess he gets free rent this week) ![]() Couple new gears.. Thanks Albert for helping me with the pump gear!! Had to go to AGCO for the crankshaft gear . New water pump.. she better run cool, mains, rods, wrist pins bushings, camshaft bearings. Toaster oven isn't for when I get hungry, well I guess it could be, use it to heat up my gears before pressing them on!I'll share some more soon, but really appreciate everything I have learned here!
Edited by ebowman - 04 Apr 2019 at 9:41am |
WD45, '62 D17 Diesel, '65 190XTD, '74 7030, 1958 Roto-Baler
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2400 |
Posted: 04 Apr 2019 at 12:23pm |
Looks like a ton of great progress, ebowman. The old girl should be ready to run soon!
WC, CA, D14, WD45
DougG
Posted: 04 Apr 2019 at 12:40pm |
Very nice work ! Keep us posted on progress
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3795 |
Posted: 04 Apr 2019 at 1:44pm |
Engine looks great! Think of the wage/hr that you’re earning by doing it yourself.
Is she a gear jumper or is it all good in the transmission department? Great pictures! Thanks for sharing. |
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3181 |
Posted: 04 Apr 2019 at 3:07pm |
Looks good. I'm waiting for someone to write a topic on rebuilding a 301 like the ones on here for a gas 226.
DougG
Posted: 04 Apr 2019 at 3:13pm |
Me too Allis Dave ,, step by step would be great , I really don't understand the special grind on the crank of a 301 diesel, its like a fillet cut ?
ebowman
Posted: 22 Apr 2019 at 3:05pm |
Update on progress... I got her running last weekend!!
couple issues: 1. i am now seeing a spark at the front pulley and the timing pointer?? pretty consistent doesn't matter the RPM 2. I have been trying to fix a leak at the injection pump. I thought it was for #6 cylinder and found a serious leak on the slotted screw on the back of the pump. Got it bandaged up and now small leak on #6 line at pump and #3 or #4 injector. I have the new valve cover "doped" up and it is not leaking in the front or back ! Trying to get her to quit seeping!! Give me some suggestions... Please Thanks
