d 17 thermostat sticking ???
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: d 17 thermostat sticking ???
    Posted: 01 Apr 2019 at 7:18pm
My d-17 project is up & runningBig smile quiet & good oil pressure. The Temp won't come up I replaced the gauge same result. I thought if it was sticking closed engine would overheat, & if stuck open it would at least get the needle off the 130 mark, "aftermarket gauge". All hoses are getting warm, open radiator & its very  warm to finger, but won't burn you. thanks keith so.va.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2019 at 7:30pm
check with a heat gun where the tube screws in head
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2019 at 9:17pm
Put the tractor to work!  It will take a long time to get temperature up if it's just putting around the yard.
