D19 new problem!
SD Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SD Allis Quote  Post ReplyReply Direct Link To This Post Topic: D19 new problem!
    Posted: 23 Mar 2019 at 4:28pm
Why would or what causes the generator on the (new to me) D19, to get very HOT.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 7:27pm
Get it rebuilt before you burn it up.
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 8:03pm
A low battery can cause a generator or an alternator to get very hot. Try putting a battery charger on the battery for a while.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 8:28pm
Question #1.  Is the charging system working?  Question #2. If it is working, what is the rate of charge?? should only be 2-3 amps unless you are running the lights. More than 2-3 amps of charge will create more heat.  Question #3.  How hot is it??   Just because you can't hold your hand on it doesn't automatically mean there is a problem, especially if the charging rate is correct. I suppose the rear bushing could be failing.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 10:57am
Is it making any scary noises?  What's your system voltage?  Put a voltmeter on it...  I don't know all the variations that would've shown up on the D19, but if there's a mechanical regulator on it, and the regulation armature contact is stuck, it might be running full field current, thus... full voltage... but you'd probably experience other very uncomfortable symptoms soon...
