d-17 pilot bearing ??
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: d-17 pilot bearing ??
    Posted: 29 Jan 2019 at 6:15pm
Does the new pilot bearing simply slide onto the end of the trans. shaft, & the crank rides against it once the engine uis in place ?? There wasn't one on it when we removed the engine. thanks, keith so. va.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 7:28pm
pilot bearing should go in the flywheel, than the clutch shaft should slide into the pilot bearing
phil
