Sickle bar identification 80/82 ETC
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Sickle bar identification 80/82 ETC
    Posted: 21 Jan 2019 at 6:18pm
Can someone help me with the identification of the twin wheel sickle bar mowers.
First ,,, what is the difference between 80 and 82 mowers ?
Then there are variations of each ?
Side mount ?  S and SI
Three Point with a tail wheel.... and without a tail wheel ?
Snap coupler versions ?
Trail versions that just hook to the draw bar.
What are the 80/82 _ _ _   designations for each of them ?
Thanks in advance.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 6:32pm
belt and idlers are differnt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 6:52pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 7:14pm
80 was the earlier model,there was a 80S side mower with a frame that mounted under the tractor,80R rear mounted on a bracket that went into the drawbar brackets,80R3 was a 3pt
mower.82S side mower hung off the right side of the tractor,82 R3 was a semi mount rear mower with a tail wheel and remote cylinder to raise and lower the blade.80T trailer mower had a straight axle across the mower,82T trailer mower had the angled axle cornered real well.Think I have examples of all of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 7:54pm
Perfect .... that is exactly the info I was looking for.....
THANKS
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 8:42pm
Another difference I remember is that the 82 has the drive bushing with slots, while the 80 had a bushing that has a round cavity or protrusion, can't remember which, for sureWink
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 9:31pm
The "Twin-Wheel" A-C mowers began with the #7.
All the other mowers you mention evolved from it.
In addition to differences already mentioned:
Later 80 models and all 82 models used a much heavier cage around the gear box along with a 3/4" thick instead of 5/8" thick cut bar.  (Big improvement)
Early 80 models had open bearings at the ends of the connecting rods. On later models,
the bearings were enclosed with a cap.
Later 80R, 80T and all 80S and 82S mowers used ball bearings at the pivot point for the raising and lowering of the cut bar.  (Another Big improvement)
The 82SI (industrial) had 2 lift cylinders; one for the mower frame and one for the cut bar.
BTW: There was also a model 82SH, another Industrial model built specifically for the Model I-40 tractor with the Industrial loader attachment.
It had all the features of the 82SI PLUS it was powered by a hydraulic motor rather than a belt.
There are probably other differences but I think I hit on the most significant ones that weren't already mentioned.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2019 at 8:43am
Bringing this back up. These mowers interest me. They seem very similar to the IH balanced head mower. I have an IH and I love it. Use it alot. They are not and never have been cheap to own or fix. So a back up would be nice.
Edited by exSW - 26 May 2019 at 8:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2021 at 6:33am
Can we get this thread added to the "knowledge base" section ?
I believe it is worthy of it...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2021 at 7:17am
Model 82-T  (pull type) had staggered wheels with the left tire being in-line with the sickle. All model 82 series had a giant jaw type breakaway device that looked like a giant clothes pin.
