6070 thrust main bearing part numbers?
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Topic: 6070 thrust main bearing part numbers?
    Posted: 21 Jan 2019 at 1:07pm
My 6070 sr no. is 1873-f and it requires the newer style no. 4 main and thrust bearing combo. Reliance and my AGCO dealer can't cum up with the part numbers for the upper and lower bearing halves. I am hoping some one on here can help us out with the correct numbers for the new style thrust bearing. Thanks in advance.
rieg
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 2:20pm
Need a size .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 2:23pm
Thrust bearing is 74006030 and 74006031 or set is 74009912 that's std size. Did you see my post on your other post. That's what I went through with 6080 maybe it's the same with 6070
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 9:10pm
Thanks for the help guys Reliance got back with me and said they are sending the correct bearing I hope it is the later style. The crank is standard size everything else in the kit fit great and they were recommended by our AGCO dealer they said that is what they use.
rieg
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 10:08pm
FYI Reliance came through with the correct thrust bearing for my 6070. The numbers for the updated bearing are 4006159 std upper and 4006160 std lower. Those are AGCO numbers the bearing actually came from AGCO.
rieg
