Weed spray's
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Topic: Weed spray's
    Posted: 19 Jan 2019 at 11:42am
Hi Guys,  Have a question for the brain trust here.  I am over ridden with russian knapweed and am looking to find a herbicide that will kill this weed.  Have tried glyphosate, 2-4d among others and nothing will kill this stuff.  Any and all suggestions will be appreciated.
Also, I have checked the county weed control board web site and they recommend tordon and 2-4d, but tordon is very restricted to purchase and spray in Washington State.  I have also looked into grazon p&d as an alternate as it is available for purchase by anyone.
Thanks
Leonard
B, 1950 WD, 3 1955 WD45, 1955 WD45D, 1969 190XT, 90 All Crop, Gleaner C2, and multiple sc implements, a david bradly rake and poo spreader(grandpa's), Deutz Allis 440HD small square baler, and others
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 12:01pm
poor man's roundup ?
jug of vinegar with cup of salt and 2-3 glugs of dishsoap
mix well....spray on , top and btm of plants
It'll kill everything..put on AFTER morning dew is gone, plants dead by 2PM !
Jay
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 1:15pm
grazon is the way to sell restricted tordon for more money.   In your position i would reach a barter agreement with someone who has the license to buy tordon and mix it weakly as everyone has the tendency to overspray with a hand sprayer.
tordon works!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 6:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 6:50pm
what Jay says!
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 7:27pm
Leonard I'm pretty sure I used dicamba maybe 2 quarts per acre??? I had 2 fields completely over run with knapweed and sprayed it in the fall. This year there was ZERO knapweed and solid grass hay. Unbelievable kill.
Blue Skies and Tail Winds
                          Dana
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 7:38pm
Hey Jay, Are those metric glugs or SAE ?????
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 7:43pm
I have used milestone. Spray the weeds as they are starting to bolt. It get drawn back down to the root system. And it stays it the ground for three years. As long as it's sprayed before the flowers seed you won't have reach urbane. Don't spray where you are going to plant beans. Manure from cows that have eaten plants sprayed with it will kill beans. I get a good kill it's very fast I spray spots working my way down the pasture when I come back they're wilting and a couple days later brown.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 7:59pm
I agree with Dave, milestone,spray at 6- 10 inches and smaller. I like grazon but as said no beans 2 years no corn 1 year. In grass / hay its ok . be cautious around gardens . don't spray if the plants are in a stress situation,best kill when active. There are some herbicides that are to be used in the fall after frost. Remember there are millions of seed there so it may take a year or two to get it. Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 8:14pm
Also our co-op is now blending grazon with fertilize. Last year was the first sold and was a huge success. About 85% effective compared to spraying. I think there is a 200 lb per acre minimum to be effective. Spreader equipment must be cleaned or designated for the blend only. I sprayed all my grazon and am pleased with the broad leaf kill in hayground. This is in TN, remember all states have differing laws.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 8:17pm
Also do not use the manure on your garden when hay has been sprayed with grazon , kill yer maters
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 9:06pm
How did this post get on shops and barn and farm equipment at the same time???
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 11:58pm
MAGIC Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 7:05am
Thanks Charlie! I believe now!!!
S_Pullman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote S_Pullman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 6:31am
Did you manage to cope with it? I have the same problem now and I don't know which tool is better to use. I used to grow cannabis, but I had weeds all the time. I have tried a huge number of different tools to fix this problem, but nothing has worked. I decided to give up this venture and switched to kratom herb, since for me it is much more convenient and reliable than cannabis. But recently a friend of mine offered me a job, for which I need to start growing cannabis again and I would like to prepare in advance for what awaits me in the future. I hope on this forum I will find the answer to my question. (and yes, cannabis is legalized in my state).
Edited by S_Pullman - 02 Dec 2020 at 2:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 8:39am
https://pnwhandbooks.org/weed/problem-weeds/knapweeds-centaurea-spp-acroptilon-repens
Herbicide Control
Please refer to the PNW Weed Management Handbook, or contact your county noxious weed coordinator.
For More Information
Selected Knapweeds of Washington Brochure
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 11:38am
Pawpaw used to swear by diesel to kill then 2,4D or something similar to maintain
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 11:57am
Does vinegar kill knapweed?
For me, the best way to kill knapweed in place is using a safe, organic compound: a half-gallon of white vinegar, (the higher acetic level of vinegar the better). Household white vinegar is 5 percent and will work fine, but 9 percent or higher is preferable.Nov 21, 2018
D14JIM14 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2020 at 2:00pm
Captain Dana has a big answer for killing any weed infestation .
Spray in the fall !! Weeds are taking their energy to the roots for winter survival .
Takes chemical to roots and weeds are gone !
Alanhey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alanhey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 7:52am
You can try CBD edibles, it has the same effect as the weed, but you don't have to inhale the carbon monoxide from the smoke which is disgusting for me. I mean this is what I am personally using for a while, and it works very well for me. In case you are interested I can leave you a link form I am personally buying https://weedsmart.net/product-category/weed-edibles-canada/beverages/. Hope you will find my message useful, and it will help you solve your problem. Have a nice one my friend.
Edited by Alanhey - 07 Apr 2021 at 8:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 8:19am
there ya go guys... Cut your WEEDS and SMOKE UM !!!.............. SPAMMER !
