7580 transmission interchangeablility????
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: 7580 transmission interchangeablility????
    Posted: 12 Jan 2019 at 12:16pm
Does a PD out of a 7060 or 7080 go into a 7580? Unknown to me my 7580 was turned up to over 300 hp and since has had multiple issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 12:27pm
Transmission should be the same. The Power Director clutch has more discs/plates in it on a 7580.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 2:21pm
I would check a parts book.   I have noticed some gears had changes in the lube system on the early 7000 series to the later.   Stuff like oil holes, groves or notches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 5:18pm
...and you just thought it ran good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 6:26pm
I had my suspicions it was a bit stronger than it should but not that bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 7:13pm
7580 transmissions are taxed to the max at 185 PTO HP, let alone any more than that. I've worked on two that have taken teeth off of the high range input gears. The tractor weighs a lot and has plenty of rubber on the ground and the tranny gets put under a lot of pressure that a 2wd tractor never sees.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 7:43pm
Currently only have high range no low range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 7:49pm
Twisted off low range input shaft I suspect. That's assuming the Power Director clutch isn't the issue.
Edited by DrAllis - 12 Jan 2019 at 7:50pm
