2500 disc
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Topic: 2500 disc
    Posted: 04 Jan 2019 at 1:58am
Looking at buying a disc, I no till and strip till and the last disc I owned was a 1020 Kewanee a long time ago. I've had a few times where the combine would leave ruts and I'd borrow a disk or use my ripper. I've been looking at International 490 and 496 discs (what I've been borrowing) and I've found an AC 2500 that looks good for the same money. It's a 25' wing fold on 9" spacings. When it gets used it will only be to level ruts in corn stalks.
Anyone have or had one?
AGCO My Allis Gleaner Company
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 2:52am
I have a center fold 2500 and it works good. The wing double fold is better as far as frame and pivot points.
https://youtu.be/OfB-6sGANy4
Wink
I am a Russian Bot
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 5:30am
About 1981 era, AC built the 2500 as a center fold or double fold with either 7.5” (20” blades) or 9” (22” blades) spacing. As a double fold, the 9” was offered with either non-cushioned or cushioned (rock flex) gangs. The 7.5” was only offered as a non-cushioned. Plain(P) or cutout(CO) blades were available. The non-cushioned specs:
A 25’ 9”P-P weighs 7270lbs.
A 25’ 9”CO-P weighs 7225lbs.
A 25’ 9”CO-CO weighs 7180lbs
A 24’-7” 7.5”P-P weighs 7255lbs.
A 24’-7” 7.5” CO-P weighs 7205lbs.
The cushioned specs:
A 25’ 9” P-P weighs 7705lbs.
A 25’ 9” CO-P weighs 7660lbs.
Drawbar hp requirements:
140hp 20-28’ (7060)
154hp 24-31’ (7080).
I have a 21’ 7.5”spacing, 2500D, double fold disk. Best leveling disk I’ve ever owned. AC built them heavy & with numerous good grease points. Mine has the optional furrow eradicators (smaller disk blades at outer end of rear gangs).
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 7:52am
We had one years ago did a good job. Only issue was the wings had a tendency to gouge. The wings had only one tire and it was mounted on the inner spindle mount. We moved the wheel, spindle to the outer position and fixed the gouging problem but then the rear gang didn't quite take out the track. I believe it was only a 25' disc. For your application, that wouldn't be a problem.
Leon B Mo
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 7:56am
Bought 1 new years ago, I think it is a terrible piece of equipment, Very difficult to level the ground with, Get it working in 1 field and move to another and start all over again, Very difficult to work with in various soil types. I personally would never buy one again.
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 8:02am
I have a 2300 series AC with the 4 smaller hydraulic wings. I believe they work really great in any condition. And are also heavy.
Cory
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 1:32pm
Considering its only being used to level fall ruts, then either a 2500 or a 2600 model will do fine.
I have a 2600 and think its great!
Yes, with bigger and heavier disks you do have to be more aware of speed (levelling) and gouging if turning too sharp. But that's normal regardless of make.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 3:56pm
2500 is an excellent disc. The gang angles are adjustable to control how much penetration there is. The one-and-only complaint I ever had on ridging was a guy who wanted to disc at 7 MPH. I rode one round with him and tipped my hat and told him to slow down to 5 to 5.5 MPH and the problem was solved. He bought a disc too small for his tractor is what it amounted to.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 7:10pm
The Allis 2500 series disks, were one of the best kept secrets in ag, great disks. The first year we had one, I was going to use it to put in oats. Dad said that it was way to heavy, and we needed to use the 13' Kewanee. Well it started to rain, and needed to get the oats covered, so we went with both disks. It was real easy to tell which disk went where, as the 2500 stand was better and, came up more even.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 9:03am
I also agree with the 2500 center fold disk. best disk I've ever owned! I do have a 470 IH and a 496 IH, some of my fields were uneven, the 2500 disk flexed good in those areas, the others would gouge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 9:04am
oh...and if you do go with either of the IH disks, go with the 490, it'll work better than the 496.
