What hardener are you using in Agco paint? |
Post Reply ![]() |
Jack C ![]() Bronze Level ![]() Joined: 15 Apr 2012 Location: E. Palestine OH Points: 73 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Jan 2019 at 8:40pm |
If anyone has painted your A-C’s did you use the OEM paint. I’m learning Valspar is the paint mfg. And it’s not a true acrylic enamel, rather a “ modified synthetic with acrylics added. (Agco spec sheet) But what I’m actually asking if you used the Agco paint, what brand/product description hardener did you use? Did you use Agco’s Renew 3001 or ??? For example PPG DU 5 . Thanks
ac160 ![]() Silver Level ![]() Joined: 02 Dec 2010 Points: 414 |
I have used the Renew 3001 that is recommended for it. Only place I could find it was a CaseIH dealer.
7060 ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Missouri Points: 1148 |
I have always used valspar renew and had good luck. I buy it at the John Deere dealer.
badjeep ![]() Bronze Level ![]() Joined: 31 Jul 2011 Location: Mt. Hope, KS Points: 134 |
Ive used everything from el cheapo tractor Supply hardner to left over urethane hardner and have had no issues ever with mixing them with the Agco paint, have always been happy with the results |
In the shed- 7020,7060, L2 X (2), CII, WD X (2), 200, 210, 611H, 440, Fiat Allis 345B
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8534 |
Using Tisco paint and hardener. Not sure if these are the same as the Valspar?
Regards, Chris
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5037 |
Does the AGCO paint hold up as good as Dupont or Nason?
dawntreader74 ![]() Orange Level ![]() ![]() Joined: 28 Oct 2013 Location: Manteno Points: 1770 |
valspar hardner works good with any imp' paint' use enamel reducer for thinner. all that mineral spirits' thinner is junk; it has oil in it 'no good an takes to long to dry.
Post Reply ![]() |
