WD45 / D17 head
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: WD45 / D17 head
    Posted: 31 Oct 2018 at 3:22pm
A quick question; Is a WD45 (4") head the same as an early D17 head?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 3:39pm
It will interchange, but the intake valves are different between the heads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 3:49pm
I have my D-17 head at the machine shop. They just called and said the head is junk. I have a WD45 4" head on the shelf. I have a complete new valve train that says "Allis Chalmers 226 (G226) Gas, LPG Valve Train Kit".
Do you think this head/valve set will work on the (1959) D-17?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 3:55pm
A "W-226" is a WD45 engine and has 45 degree intake valves. A "G-226" is a D-17 engine and has 30 degree intake valves.  Don't know what your parts are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 6:50pm
Thank you DrAllis !!!
Are all the other parts the same (exhaust valves, guides, springs, keepers)?
Edited by WF owner - 31 Oct 2018 at 7:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 7:01am
Everything else is the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 10:46am
What's wrong with the head?  Is it cracked?  Been ground too many times?
I'd bet there's somebody here that has one for pretty cheap....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 12:06pm
If it is being condemned for cracks at the spark plug holes?? Tell them to ignore those cracks. Never seen one that didn't work just fine that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 5:59pm
The tractor had set with the exhaust uncovered and, of course, rain water ran down into #2 cylinder. He said the head is rusted really bad around the valve guide and is too badly deteriorated to hold the guide.
As I said above, I have a WD45 head on the shelf (hopefully it is a good head!), but if anyone has a D-17 head at a reasonable price, I am interested. Otherwise, I will probably just buy the intake valves for the W head and use it.
Edited by WF owner - 01 Nov 2018 at 6:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 1:19am
If I remember correctly, I have some NOS valves for the 201/226 heads. I’ll take a close look to see just which ones they are after I get home from work later today.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 5:46am
I have a couple a D17 heads I'd sell plus other parts the guy I bought this one from tore everything apart did some work then quit the project I bought it to get the wide front and PS to swap out on another tractor.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 8:15am
I have rebuilt WD45 heads on the shelf. New valves,guides,springs,keepers, and expansion plugs. Tested for cracks and machined on the head and intake surface. $350.00.
Jamon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamon Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 2:51pm
Do you still have D17 heads?
jeickman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 4:41pm
"A "W-226" is a WD45 engine and has 45 degree intake valves. A "G-226" is a D-17 engine and has 30 degree intake valves.  Don't know what your parts are." Is Dr Allis talking about valve seat angle here and if so, can't the valve seats just be ground to match the valves you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 10:13pm
doubt the seat would have enough material in the right area to get the contact point where it should be....guess you wouldn't know till you tried it or at least looked it over carefully before hand
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 7:33am
manifold studs are different sizes, wd45 has 3/8" bolts and the D17 has 7/16"
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 7:37am
At that point I'd consider new seats.
Wink
I am a Russian Bot
This page was generated in 0.052 seconds.
