7000 transmission brake-pedal travel question
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Topic: 7000 transmission brake-pedal travel question
    Posted: 21 Jul 2010 at 11:16am
How far down should the inching pedal go down before the brake engages?  I adjusted mine per the bulletin TBran sent me and the brake engages when the pedal is about half way down.  I check this by turning the PD housing by hand while the guy I work with pushed down the pedal slowly.  I feel like I did something wrongly.  I double checked all my measurements and they looked good according to the Allis service bulletin (4.6 inch spring length and .25 inch gap between the spacer and the front adjusting nut all with the pedal down against the pedal stop).
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2010 at 12:52pm
If the clutch pedal is all the way down to the stop bolt(very important...to the stop bolt) there should be the .25" (1/4") gap between the spacer like you said. That's all you need to worry about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2010 at 3:55pm
I'll have to double check on that again.  It may have been stopping on something else, like the rubber boot or floor pad.
Hurst
5800 Hours
