Flushing a diesel truck cooling system |
DougG
Topic: Flushing a diesel truck cooling systemPosted: 11 Oct 2018 at 2:30pm |
Any thing to use except the off the shelf stuff? Have used that stuff before but seems like it didn't help much , Anyone use anything else ?
Edited by DougG - 11 Oct 2018 at 2:30pm |
Red Bank
Joined: 18 Apr 2018 Location: Germanton NC Points: 1051 |
Posted: 11 Oct 2018 at 10:07pm |
What kind of truck which engine what year?
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34405 |
Posted: 12 Oct 2018 at 6:14am |
Water is still the best, I do NOT care for chemicals inside a cooling system you may or may not be able to neutralize. Get the chunks and rust out then refill with GOOD full strength coolant and distilled water for a refill and most times the rust does not return so fast.
There are coolant additives available now that were not so prevalent just twenty years ago to aid in controlling deposits and corrosion, well worth it. |
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3292 |
Posted: 12 Oct 2018 at 6:34am |
Depends on what you're trying to fish out. Just trying to get the rust out, or did you have an oil cooler go bad and get oil in the system?
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
DougG
Posted: 12 Oct 2018 at 6:46am |
99 Cummins, no oil or anything like that just rust from the years
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12250 |
What do you mean by "help much"?
Red Bank
Posted: 12 Oct 2018 at 11:13am |
Ford has an iron remover flush that I have used with success. It's available at Ford parts counter
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 12 Oct 2018 at 3:40pm |
Permatex heavy duty radiator cleaner. Careful though, it is pretty much straight acid and does a VERY thorough job. So thorough that if you have any areas of the radiator or thermostat housing that's getting thin or held together by rust it will start leaking. Turned the original radiator on my WD into swiss cheese, but that was probably for the better if it was that bad. Flush well and add some baking soda to the flush water to neutralize what's left.
