B lift leaks down
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: B lift leaks down
    Posted: 28 Sep 2018 at 3:55pm
Move lift lever to the up position and lift comes up, however when lever is released the lift leaks down.  Lift cylinder is not leaking around the shaft.  Did remove pump and disassemble cleaned out gunk and put it back on.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 6:01pm
  Had same trouble.Took apart 3 or 4 times.Seat on relief  valve is leaking .When land where ball sets gets to wide it will leak.Took mine to machine shop and removed 10 thousands and now it holds.Where ball sets needs to be almost a sharp cornner. Had same trouble with check valves at work.Fix a bunch when working.
This page was generated in 0.058 seconds.
