7000 Series Dash Removal?
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Topic: 7000 Series Dash Removal?
    Posted: 09 Sep 2018 at 3:49pm
Hey all,
I did a bunch of searches with a few different key phrases, and never could find much, so I figured I would start a thread in case someone in the future needed the same info.
What is the best way to remove a 7000 series dash?
(Maroon belly 7040 if it matters)
If it was a simple replacement of something I would do it from the top since that is easier to access, but this is a new to me unit with packrat damage, so there is going to be some major wiring reconstruction that would be made easier if the dash came out 6 inches.
Any info appreciated,
Thanks!
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2018 at 4:01pm
there's 2 allen head bolts at top, and 3 on bottom, then I think it will pull away, only be wires holding it.
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2018 at 5:50pm
Ed is right about the allen head bolts. The worst part of pulling the plastic dash is it won't come straight out.  The sides of the plastic extend into the orange panels on the side (you can see where they follow the curve on the lower part of the plastic).  You have to loosen up at least one side to get the dash panel pulled up.  Now just to get the sides loosened you have to remove several panels to get at the bolts under those side pieces.  Would have been great to just be able to pull it straight up.  If you need to I can take a few pictures of the panels I have apart here.
