WD 45 Block
Mossman42 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mossman42 Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Block
    Posted: 29 Aug 2018 at 6:23pm
Hello all, I have a couple questions to ask if you guys. First off, I am currently restoring a 54 wd45 and I have the engine tore apart and down to the bare block. I have cracks on the tip of the deck where the liners seat. So I asked a machine shop if they could fix it. They didn’t seem to want the job and wouldn’t garuantee a fix. So now I am searching for a new block. Is there anywhere you guys could lead me to find a block that isn’t cracked or just in good shape?
Second, I was wondering if these cracks on top were a common thing for these wd45 tractors.
Thank you guys for the help.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 6:37pm
I've heard those cracks are normal. You can use the block off a WD with a tall head, but you never know if it won't have cracks of its own.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 8:14pm
some 15 years ago i cleaned the cyl's good an put it back together put J-B weld in them little cracks put head gasket on an the head an titened it down; never had a problem after that. plowed with it many times. left it set over night before i put any water;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 8:15pm
Welcome Mossman42,
You might want to take some good pictures of the cracks and post them or have folks like Don(MO) look at them. You might be ok? Good luck on your rebuild. You don't have another 45 block setting in the corner? Humm thought everyone did!:) There are engines out there, Just need to find one close to home.
Edited by Sugarmaker - 29 Aug 2018 at 8:16pm
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 8:30pm
Many of them have small cracks in between the cylinders. The head gasket (with sealer applied) tends to seal them up. I don't think you will have a problem.
If, on the other hand, you have cracks at the bottom, your block will probably be no good.
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 8:31pm
Yeah, would love to see the pics of these cracks. Seems like many an old block has been salvaged. Surprised a machine shop wouldn't want to work on it. Seems like cracks in the webbing on these old blocks is kind of common.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 8:45pm
if the sleeves will clean up' leave them alone' seal the top before the gasket'
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 8:49pm
Cracks at the top of the block are acceptable - not the bottom.  I had a D14 engine rebuilt with the cracks up top and it has never caused any problems.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 11:01pm
if dont intend on pulling the sleaves , bolt them down before you hone or work on cleaning them up so as not to take a chance of messing up the old crusty o rings  and end up with water in the oil down the road
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 7:26am
A restoration project ??    If it is cracked in all three places on the top deck surface, I wouldn't even consider reusing it for a tractor you are spending some $$$$$$$$$$$$ on.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 9:28am
If It Is Cracked At Top Between Sleeves that Is Normal . I Built Pulling Engines  With The Cracks .If you Find One Not Cracked Let Me know
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 8:05am
I have rebuilt WD/WD45 tractors with one or even two cracks in the top of block like most of the guys out there but and it's a big but not if the cracks run down the block or if all three cly are cracked. I like to just find a good block and with around 84,000 WD45 gas engines built over it's run I have no trouble finding a good one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mossman42 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 3:22pm
Here are the pictures. From front to back between cylinder 1 and 2 is the worst cause it is cracked all the way around. The other two are hairlines that have started.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mossman42 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 3:29pm
I’m not very good uploading these pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mossman42 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 3:33pm
It won’t let me post the other pictures of the other cylinders. But they are very small and not near as bad as the one that I showed the pictures of. Both of them each are about a 1/4 in crack
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 7:45pm
The pictures will help folks that know more than me, guide you in next steps with your block.
Do you have any cracks at the bottom of the sleeves? Mine had similar cracks at the top and also corresponding cracks at the bottom. It now sets in the junk pile! :( Hoping my second block gets through magnaflux. There were no visible cracks in the second block.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 8:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mossman42 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 8:18pm
The bottom end looks fine, I didn’t see anything wrong with it. It’s just the top on the deck that has the cracks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 9:28pm
Put it together and forget it.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mossman42 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 11:10am
Thank you guys for all the info. You guys were pretty quick to respond to this and I thank you. I’ve got a tractor show here in elnora I’m going to go to and see if any vendors have anything I could use. If not I think I’m just going to resort to plan B and doctor the cracks myself. Thank you all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 11:22am
The nice thing about those cracks is this.......they haven't spread apart and the deck surface appears to still be flat.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 2:24pm
do not...I repeat...do NOT "doctor" those cracks in any way, you just run the risk of making them worse and turning a usable block into junk. Those cracks are about as tight and smooth as can be, put it back together normally and forget it
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 6:48pm
I second this! LEAVE it be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 10:04pm
I third that motion, just make sure your lands  are absolute clean of anything when setting the sleeves back in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2018 at 8:28am
When putting the sleeves back in, put them in without the O-rings first and make sure they fit freely and turn 360. Then check stand out of the shoulder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mossman42 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2018 at 7:09pm
I practiced nickel welding on a piece of cast iron. Glad I didn’t do that on the block haha! Got the cast real hot prior to welding, still cracked. So doctoring is out for me
