siderail flexing 7030
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Topic: siderail flexing 7030
    Posted: 18 Aug 2018 at 12:29pm
How is the best way to fix the siderail flex on a 7030, with a loader? The siderails flexing is so bad that the front plate on the engine moves and the bolts are loosening up and front crankshaft seal leaks all the time. The dowels are loose in the front plate and the engine block. HELP PLEASE !!!!
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2018 at 10:24pm
Don't know if the front axle would clear, but could one swap on the 4wd frame rails from a 8000 series? They are 2 inches wider if I remember correctly.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2018 at 11:09pm
I'll see if I can get you some pictures of the westendorf on my 8010 an how its done...I can text them easier if ya pm your cell #...
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 4:20am
are you talking about the frame along side the engine? what made it start flexing? I have some frame off my 7080
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 10:14am
We had the same thing happen to our 7040. Bought the tractor new in 1976 installed a Leon 10' dozer blade for snow removal. The front of the undercarriage bolted up to the weight carrier thread bosses. First noticed engine oil leaking up by the front cover area. Cracked the oil pan once and had to replace with new one. Put up with it for a couple years, then Leon designed a new front mount that bolted to the front axle. Needless to say it relieved the stress and twisting on the front bolster and haven't had trouble since. Have had the same thing happen with a 200 and a WL42 Westendorf loader. Fixed it back up and use the FR10 wheel loader for the heavy work. I do like the idea of using the FWA frame rails. Good Luck, Mike
