WD 45 Rear Rim
Gary(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Rear Rim
    Posted: 05 Aug 2018 at 9:54pm
What is the going price for a WD 45 rear rim 14 inch ? (NEW) Thanks Gary
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 2:18am
Somewhere in the $400 range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 7:15am
Widest rim for a WD-45 was 12 inches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 7:29am
D17 rim may be wider and fit too? Yep that new cost sounds about right. Guess thats why I try to save them if possible. And Yes the std rim width is 12 inches for a 45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 8:17am
I've gotten rear rims off of a one-owner D-17 IV and they were 13 inches with 16.9 x 28 tires..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 2:32pm
Thanks guys. I have not measured rim but was told from 13 inch to 14 inch was wd 45. I know what to look for now. Thanks Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 2:50pm
Measured from the INSIDE of the bead lip flange.
polarbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 6:08pm
cross manufacturing
Mindenmines mo
it is located around Lammar Mo south of Kansas City
good people $250 to $300
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2018 at 7:00am
If you're buying new rims, buy them off of what size tire you're putting on it. Not what is correct for the tractor. The tire guys can help you with this. a 13" rim is for a 14.9 tire, 15" for a 16.9. You can go one size either way and be ok, but if you're buying new, you might as well get the best one.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2018 at 8:24am
Mine had the suggested rim size on the sidewall of the tires.  I believe I paid $250 for the one I bought, but that is in MI, which would make it a little more with S&H for you.  The one I bought had the slide rails welded along the the sides of the rails not the original way they were welded.  I was not doing a restore so it didn't matter to me.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2018 at 8:54pm
I put 2-13" rims on mine with 14.9 x 28 tires-Firestone. Original rims were 12" as Doc said. That size tire really works nice with the wider rims.
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2018 at 9:43pm
I fixed up a couple of rims of one of our 17's series 4 and they measured 13 inches like Doc talks about. These had 16.9x28 Firestone field and roads, Going to put on new Firestone 23 degree SAT II 6 ply's.
