model m trans and final fluid?
Matterhorne9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matterhorne9 Quote  Post ReplyReply Direct Link To This Post Topic: model m trans and final fluid?
    Posted: 02 Jul 2018 at 1:15pm
the manual said 30 to 50 w oil for the trans and finals. mine had 75w-90 in them. should i stick with the current oil or go back to the factory spec?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2018 at 8:27am
80-90 is fine unless you run it during the cold montana winters, then you might consider a lighter weight oil for winter use if my assumption of your location of Billings is correct.
Edited by CAL(KS) - 05 Jul 2018 at 8:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matterhorne9 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2018 at 8:30am
Thats the conclusion i came up with. But oil any oil at this pioint is better then what was in it. Hahaha thanks
