170 Gas Baling |
Post Reply ![]() |
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3092 |
![]() ![]() ![]() ![]() ![]() Posted: 31 May 2018 at 7:09am |
Anyone pull a round baler with a gas 170? I have 2 Oliver 1550 tractors gas and diesel I pull a NH 851 baler with OK and they are 53 PTO HP and I'm thinking about a gas 170 that's rated at 54 PTO HP but wondering if the gas 4 cylinder has the power to get the job done?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21998 |
53 or 54 HP from a 4 cylinder should be the same as from a 6 cylinder. Torque X RPM makes HP.
Guess you're right but the reason I wanted someone to chime in that's run a 170 on a baler is I have a 4 cylinder International about the same HP and governor stays wide open once the baler starts to make a bale and its just too much for the IH to pull.
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Well Gary being all your ground is on the flat and level . LOL
Edited by Fred in Pa - 31 May 2018 at 9:51am |
wekracer ![]() Orange Level ![]() ![]() Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
I have pulled an 851 with my 175D in the past and it is a load. Up hill with a full bale is all it wants. I don’t remember what the hp is on it. I think around 65. If you have a bigger horse I think you would be better off using it.
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
The torque curve is probably flatter on a diesel. |
allisbred ![]() Orange Level Access ![]() Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
I would look towards a 180-185 with hydrulic engagement on the PTO-- since you have not bought anything yet. Just my thoughts
I have a 180 and a 185 but wanted to know if the 170 would be capable to use on the balers if needed.
Post Reply ![]() |
