D17 Gasser
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: D17 Gasser
    Posted: 26 May 2018 at 6:56pm
Bugger wont run unless choked.....carb is getting plenty of fuel.
What now?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2018 at 7:12pm
Leaky intake manifold. Float level wrong. Partially clogged jet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2018 at 7:44pm
Open up the main jet 2 or 3 turns. What did you do to the carb??
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2018 at 8:12pm
I'd spray carb cleaner around all fittings and see if the engine tone changes. If so, you found your leak. Some guys also use the gas from a non-lit propane torch, as it produces similar results.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2018 at 9:07pm
Has the carb had a good cleaning?  Might want to do that first.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 7:54am
You might have done it already, but I have found the fuel goes bad. I drained my D17 that had new fuel in it a month ago, left it in an open pail and after a week still has fuel in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 7:35pm
Fresh fuel,
Carb was rebuilt not too long ago, but yes it may need cleaning.
Actually I dont know much about the workings of a carb, but willing to tear into it if I must.
Manifold is newer, hope there isnt a leak!
Thanks guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 7:53pm
I think I would put the carb on hold and look at ignition. I have seen points, condensor and plug wires cause this problem. Drives you nuts until you find it. Had one that I messed with a long time and found a wire shorting against the block. To soon for the gas and match.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 7:59pm
Plugs are less than two years old, had ignition overhauled at same time...so hope its not ignition but will keep that in mind and do a look see... thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 8:00pm
Is this carb a marvel  schleber? (sp)
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 8:17pm
Did research, yes I have a schebler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2018 at 8:33am
So i decide to try again saturday. Now it runs fine
Go figure
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 10:24pm
Maybe had some bad gas. Glad you got it going!
