Mid $ loader recommendations for Maroon 7000?
erikIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote erikIL Quote  Post ReplyReply Direct Link To This Post Topic: Mid $ loader recommendations for Maroon 7000?
    Posted: 20 May 2018 at 12:58pm
Short version-
I am just beginning my loader search and wanted to know if anyone with a 7000 sized tractor with a loader can describe their experiences (good and bad) with aftermarket loaders.
Long version-
I am looking for a loader for my 7000- for moving large round hay bales (5' by 6'), scooping silage and maybe loading old cow manure into a spreader.  I would not be doing any heavy duty dirt digging with it (I have an old back hoe for that).  I also already have a 90hp tractor with a very stout JD148 loader that I use for large round bales and moving/back dragging gravel.
The loader on the 7000 would be more of a convenience than a necessity.  To be honest, I just bought a very heavy 12 row IH 800 cyclo corn planter that is partly carried by the 3 point hitch and when I hooked it up to my 7000, I found out that I wouldn't be able to steer without adding a lot of front end weight (I currently have no front weights).  Rather than just spending around $800 on a full set of front end weights, I figured that for an extra $2K more than the weights, a loader would not only give the front end ballast that I need to steer the planter but also would be very handy for other jobs.
I am hoping to not spend more than $3500- but cheaper is better.
I came across ads for a Bush hog QT 2400, a Westendorf TA 28 and a Bush hog QT 2840.
The Bush hog QT 2400 is cheap and already has brackets for an AC 175.  The owner states that they are adjustable brackets and it will fit many tractors with side rails- but I wonder if it would be built heavy enough to move large round bales without flexing/bending...
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 1:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 1:11pm
Too big of a loader on a model 7000 tractor will cause the side frames to flex in front of the engine attachment point. You can have injection pump seizures, loose timing cover/front plate bolts and cracked/leaking engine oil pans. If you must, better brace those side frames between the engine and front support. Be careful when carrying heavy loader loads.  I know this for fact because of a Customer who seized two injection pumps over a period of 6 or 8 years. Each time he was using the BIG loader.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 3:29pm
I,ve had convenient loaders on both a7020 and a7045. Westendorf is the best. Bush Hog is ok just not as easy to put on and take off. Either will have to be off to get side panels removed. Contact either company and you can get the correct mounting brackets. You won,t have a loader tractor, you,ll have a tractor WITH a loader. Still better than a scoop shovel.      The 2840 BH will be the heavier.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 6:55pm
If you are thinking more convenience for weight than need I would go with weights, way better visibility and no tractor damage.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 7:15pm
Short version- I wouldn't do it.                                                Long version- The Dr. is correct, it takes a large,wide frame loader to mount on those tractors. It's hard on the front ends,unless it has the eight bolt front wheels or is a 7000 special. It can damage the front cover gaskets or worse from flexing of the frame. The foot clutch will require more maintenance from constant use and the hydraulics are a little undersized for a big loader.
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 7:20pm
   Howdy.
   I have a Dual 340 loader for sale. Its on a 170 but too much loader for this tractor. Has to be one of the newer loader, has rectangular frame.  7 foot bucket and strong. Now woods dual loader is new company.
  Kurzy
Post Options Post Options   Thanks (0) Thanks(0)   Quote erikIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 7:29pm
Thanks guys.  I definitely don't want to over stress anything or cause any damage.  I will be looking for a full set of front weights.  Anyone in the IL area know of a good salvage yard in the area with AC 7000 weights?
Kurzy- thanks for the lead on the loader- good luck selling it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 8:42pm
Agree with Dr. And others. Have worked on a lot of them with same problem.     MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 7:50am
X2
I'd put a loader on almost anything else over a 7000.
Edited by Lonn - 21 May 2018 at 7:51am
Wink
I am a Russian Bot
