Allis Chalmers WC
Daniels wc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniels wc Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers WC
    Posted: 12 May 2018 at 9:28pm
Last summer I had got my WC running. Had it out and was using it and knoticed it started to over heat shut it off and check coolent. It had plenty a day or so before but it was all emty. Then checked oil and it was cream color wondered where the coolent could be getting by to make the oil cream color? I had guessed it was the head gasket because it apered to be leaking. After taking the head off the gasket apered ok ish just old. If you have any advice or info let me know thanks
Edited by Daniels wc - 12 May 2018 at 9:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2018 at 9:50pm
Block cracked between sleeves at bottom.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2018 at 10:04pm
As MACK says, or a bad freeze plug or bad o rings on a sleeve.
