Allis Chalmers 230 gas combine engine in WD45 |
Post Reply ![]() |
Preston230 ![]() Bronze Level ![]() Joined: 08 May 2018 Location: Home Points: 17 |
![]() ![]() ![]() ![]() ![]() Posted: 08 May 2018 at 9:24pm |
Ok so i wanna put a 230 gas combine engine in my wd45 gas frame. Will i have to do anything other than a starter, flywheel, and adaptor plate. Will i need to have my crank ground or anything?
Thanks Preston |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21899 |
Gas radiator won't work. What are you using for a governor and throttle linkage??
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3085 |
I have put a couple in diesel frames that gives you the adapter plate,starter,radiator,hood and flywheel,as far as the governor and making a front mount the front plates and governor off a Cockshutt
30,40 or 50 makes for the easiest conversion. |
Ok Thanks for the information. I will probably have to find a governor for it and use linkage off some thing else or make it.
Post Reply ![]() |
