Allis D-14 wiring problem
Dana Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dana Miller Quote  Post ReplyReply Direct Link To This Post Topic: Allis D-14 wiring problem
    Posted: 11 Apr 2018 at 10:22pm
I am putting A new ignition switch {2-wire} in my D-14.It starts,runs, but when I turn the key off it keeps running.Has been converted to 12 volt.I am not sure I put the yellow wire in the right place,also has A start button.I just need to know where this yellow wire goes...I forgot! Thank you!
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 4:20am
Does it have an alternator? If so you need a diode or lamp on the exciter line. You can also change the 2-wire ignition switch to a key switch and use the ACC position for the exciter line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 5:55am
Hmm.. yellow is the coil feed, through the ballast resistor. Since it was 'converted to 12V' , I'm with DougS and thinking it has an alternator on it now.
If so, the alternator wire is attached to the ignition switch on the coil side. Removing the alternator wire and putting it onto the other terminal of the ignition switch( the 'feed' side) will solve the problem.
I'm basing this on fig 184 of the I&T book, wiring for D-14 tractor.
What's interesting to me as none of the 3 wiring diagrams show a ballast resistor, and all 4 of the D-14s I'v had have them....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dana Miller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 11:12am
has alternator,and key switch,also has push start button.wouldnt shut off when I put key in off position.thank you for responding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dana Miller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 11:27am
headed out to do this.hopefully this ole farm girl gets it right. thanks again Dana
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 6:51pm
Did you get a wiring diagram with your kit?  Not all kits will use a yellow wire going to the same place.  When in doubt, look over the wiring diagram and match up your wires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dana Miller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 9:10pm
no schematic was sent, but I followed what Mr.Miller said.Decided to re-wire all the hard old wires,and added A dash lamp and headlight wires today.Got it all done. Ran out of time for today to start it.Tomorrow I will run it and see.Thank you Dana Miller
