Making T-stat Gasket?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: Making T-stat Gasket?
    Posted: 05 Apr 2018 at 8:02pm
Didn't order a thermostat housing gasket(head to housing) for my D17 engine repower. Can I make that gasket and if so, what can I make it out of? Really want to get her running this weekend and can't source it locally anywhere.
AaronSEIA
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 8:19pm
Hey Aaron,,O'Reilly's has a "kit" of 4-5 different material and thickness gasket making material that will do the trick for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 9:00pm
Beer box, and a tube of blue goo...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 10:19pm
could just use light smear of rtv alone
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 10:44pm
I've heard of that being done quite a bit. Sometimes without the blue goo even...
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 12:33am
Order one from your local AGCO dealer.  They will courier it out to you (for a fee) and you will get it in a couple of days.  You know it is the right one you need too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 7:55am
Clean both surface with brake kleen and use good quality RTV and you will be fine.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 8:02am
I would go with the good RTV as suggested.
I recall the ole beer box gaskets deteriorating with time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 8:41pm
Get your gasket paper, clamp the housing upside down in a vise, lay the paper on the housing and tap the edges of the housing through the paper with the round end of a small ball pein hammer. You'll end up with a perfectly shaped gasket that fits right.
