CA front weight
bigredneck61088 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredneck61088 Quote  Post ReplyReply Direct Link To This Post Topic: CA front weight
    Posted: 05 Apr 2018 at 5:13pm
How are you guys holding down the front of your CAs? Mine needs some weight and I have access to some suitcase weights, anyone build a bracket for those on a CA? Or would I be better off with front wheel or side weights. I have new tires and tubes in the front so they could be filled, but didn’t think that would make much difference.
Thanks in advance!
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 6:40pm
I've got front wheel weights and they'll help a little but not a whole lot. Those engine weights are pretty hard to find
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 7:05pm
Pretty easy to modify a JD garden tractor weight bracket to bolt onto the front cultivator
mounts to use suitcase weights.Nice thing about suitcase weights is they are easy to take
on and off as needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 4:03am
Have you added a 3 pt? Most any of the factory equipment can be balanced with a pair of side weight and if needed a set of wheel weight. If you installed one of those aftermarket 3pt kit, you need to find anything heavy that is available. Maybe a seat out front for the MIL
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredneck61088 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 7:27am
Gary, got any pictures of one modified, sounds like a good option...
Paul, still on the factory AC gear, but moving snow with a AC blade I could use some steering weight...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 8:04am
No pictures but really all that needs to be done is maybe drill a hole or two to line up
with the CA depending on the bracket.I don't know which JD garden tractors my weight brackets came off as a friend of mine had a pallet of them and gave me several.Some
were wider than others.They are well made heavy duty brackets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredneck61088 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 4:34pm
I just checked ebay there are a million different John deer mounts, is it the front mount or rear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 7:13pm
THe ones I have were front mounts
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 8:10pm
On my CA I welded a piece of steel 6 inchs long by 1/2 inch to the top of the axle with a small piece of steel welded on top of the 6 inch piece to keep the suitcase wts from moving sideways. I just use them when the rototiller is being used, it is easy to take wts off.
