what was the difference
Message Reverse Sort Order
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Topic: what was the difference
    Posted: 22 Mar 2018 at 8:32pm
them ac-45's worked good in them old trucks also' like the gm 6 cyl 292
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2018 at 9:47pm
Back when big truck engines were gas burners (like 2 ton) they would burn them light weight plugs up pretty quick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2018 at 3:28pm
there a good plug for the wc-wd-wd45-d17 an more 'they are a hot plug' better spark for a working tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2018 at 2:46pm
Longevity under harder conditions on the "commercial" version...
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2018 at 1:43pm
Well Steve,,Don,  I didn't  buy these so I can't checkem out.I was just curious if there were any advantages to these over a regular plug.I can't say that I've ever seen the commercial version before.Didn't know such a version existed.What was the advertised advantage?
Edited by ac45dave - 21 Mar 2018 at 1:44pm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 11:02pm
Dave you will like them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 9:38pm
compare the center and electrodes to "regular" plugs....you will see
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 9:03pm
between the plain ac 45 plugs and these ac c45 plugs to call them commercial.Does Bill Long or any of the older generation know or remember?
Edited by ac45dave - 19 Mar 2018 at 9:03pm
