220 only runs on either momentarily
Kingz Livestock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kingz Livestock Quote  Post ReplyReply Direct Link To This Post Topic: 220 only runs on either momentarily
    Posted: 16 Mar 2018 at 2:17pm
I have a 220 landhander that will only run on either for a few seconds, needing ideas to what's wrong. Thanks.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 2:20pm
Pump issues or plugged fuel line and/or tank
How blessed we are by HIS GRACE!
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 2:28pm
pump shut off pulled out?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 2:35pm
I bet it's been sitting a while. The plungers in the pump are stuck, and it will not pump fuel until pump is properly repaired, and all of the fuel lines and tank need cleaned.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kingz Livestock Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2018 at 11:32am
Thanks, Turns out pump is bad had a bunch of black chunks in it when I pulled the top off. Not being a mechanic I pulled the pump off without knowing I had to line up the timing marks. How bad is it to time the engine when I put the rebuilt one back in??
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2018 at 1:26pm
the shop who rebuilds it for you should be able to coach you on re-installation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kingz Livestock Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2018 at 1:57pm
Ok thank you!
