190xt series 3 Power director fittings and hyd li
Allis Magoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Magoo Quote  Post ReplyReply Direct Link To This Post Topic: 190xt series 3 Power director fittings and hyd li
    Posted: 25 Jan 2018 at 9:55pm
So I assume I am not the only one to ever break the jic fittings off the PowerDirector if so I'm trying to figure out how hard it will be to get the fittings out also does anyone have the hard-line hydraulic tubes that they would be willing to sell
Edited by Allis Magoo - 26 Jan 2018 at 11:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 10:04pm
What tractor and which fittings?    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Magoo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 10:06pm
Hahaha my bad talking to myself again 190xt series 3. On the power director there are 2 fittings in the collar. And I bent the hard lines
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 10:17pm
Fittings are not usually very tight in housing. Easyout should remove fitting. Steel line can usually be straightened.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Magoo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 10:20pm
Ok ill get a pic and see what you think I kinked them pretty hard. This is what happens when you don't read the book and don't unhook the lines before removing the rear
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 7:29am
O, sounds like you may need new lines.    MACK
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 8:40am
Most of the time sealing rings cut groves in the housing n it needs to be replaced anyway. If u r talking the retainer for input shaft that the PD sides into. ,
nonetheless ,still dead.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 9:56am
Are the fittings inverted flare or JIC? I thought they were Inverted flare. The tubes changed at SN 9666.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 2:24pm
I have the lines and fittings if you haven't already found them.
