Need a Hesston part
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Topic: Need a Hesston part
    Posted: 22 Jan 2018 at 11:05pm
Can any of you AGCO dealers out there give me a price or link to a dealer for part #700152293 standard or #700717701 Heavy Duty skid shoe for a Hesston 1345 Hydro Swing disk swather.  I wonder if those parts are used on other models?
Allis Express participant
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 6:59am
John, I can't tell you the model but I got the shoes for a 1320 at the case in dealer. They sold the hesston painted red
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 8:31am
There are some new idea parts that Interchange also...
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 1:14pm
Can you weld on some really hefty leaf springs from a truck? Last time I rebuilt the skid plates.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 1:22am
One is too badly worn out, didn't see the problem until it totally wore out in front.  There are 8 on the machine but only the outside ones wear much.  I probably will weld springs onto the still good ones.  Stopped at the IHC/NH/Kubota dealer on my way to Greeley today.  CaseIH uses the same numbers for stuff they bought from Hesston before buying NH.  The price from them was $80+ and didn't have them in stock.  Parts guy said they are cheaper at MF/Hesston in Greeley so stopped there also, got two of them for $92.  Quite a bit cheaper. While at the Kubota dealer asked about the smaller window on the back of the cab of my M110, a small rock got flung at it by the Hesston baler last year.  It's maybe 2' X 10" with a hole in each corner.  I guessed it would be a hundred bucks or so, $260!!  I've got a piece of plywood in there for now but can't see the drawbar without opening the big back window.  Think I'll buy a piece of Lexon plastic and use it instead, plus it won't break it a rock hits it!
