58 d17 dsl power steering line |
Post Reply ![]() |
LazyDFarms ![]() Orange Level ![]() ![]() Joined: 07 Feb 2010 Location: Coleridge, NE Points: 203 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Jan 2018 at 2:21pm |
Looking for the bypass line on my 58 D 17 dsl. Agco part#70229839 or the old allis part #229839. Used or new, any help is great. Thanks Dennis
I'VE DONE MORE WITH LESS!!
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7484 |
Have you checked with AGCO? You would be surprised that they can still get some of that stuff.
DonDittmar ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2515 |
Have a picture of it? I have some lines off a 17 diesel.
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Agco is no go, I don't have a pic because I don't have one, Agco part #70229839
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
That line has a hose section in the middle. If is just the hose part the is bad, there are crimp fittings that are made to braze or weld to the tubes and then crimp in place. I had to do this for the lift cylinder hoses on my 180, and also on a 72 GMC power steering hose.
Kevin in WA ![]() Orange Level Access ![]() Joined: 08 Feb 2010 Location: Lynden, WA Points: 612 |
If you decide to make one, be sure it is long enough to extend down below oil level in the front support or the pump will suck air back through, the pump has a passage from the relief valve area to the inlet port.
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Merrill Wi Points: 2022 |
I parted out an early D17 diesel last fall. All the power steering lines are there. I don't have a parts book can you send a picture?
orangereborn ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: NW WI Points: 1470 |
I'll try this...
Post Reply ![]() |
