Front Loader Info. for Allis 6060 cab
RKBARRELHORSES View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RKBARRELHORSES Quote  Post ReplyReply Direct Link To This Post Topic: Front Loader Info. for Allis 6060 cab
    Posted: 15 Jan 2018 at 1:37pm
I am in search of information for front end loaders that will fit a 1985 Allis 6060 cab 2 wheel drive,I am looking for used in good working order make and model that will fit or has came off of a Allis 6060  without modifications made to the loader or tractor, any Info. on mounting brackets,bolts,hydraulics,hyd. tank,pump,valve bank,hoses,pictures,price,etc.that I would need, I have found a couple of loaders but had to be modified to work on my 6060,I don't want to have to cut and weld and extend or modify. Thanks, any info. will be appreciated Thank You
Tim (Cent.WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim (Cent.WI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2018 at 3:15pm
I have a Leon 700 on my 6080 2WD
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2018 at 4:30pm
Here is my 6080 with a factory allis 460 loader.  Should fit all the 6000 series.  This would be the best one I know of for a direct bolt on unit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2018 at 9:23pm
Sounds like you need to buy one from a dealer put on.     MACK
