45 diesel fuel leak into oil pan
Allan Drone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allan Drone Quote  Post ReplyReply Direct Link To This Post Topic: 45 diesel fuel leak into oil pan
    Posted: 03 Dec 2017 at 7:25pm
My father in law has a 45 diesel that we have been fighting for a little while. Diesel fuel keeps leaking into the oil pan. Have resealed a few things but kinda scratching our heads. Any suggestions would be greatly appreciated.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 7:39pm
Two things to look at are the lift pump shaft seal ( the lift pump in the lower left side of the injection pump), or the O-ring below the injection pump head.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 9:29pm
I took some pictures of the O-ring Don mentioned.  When you take the cover off for this area there should only be motor oil in there.  If there is diesel fuel then this is where you have a leak, so this one is real easy to check.  Here is a link to my pictures: http://allis01.com/fossto/56WD45D/ac-wd45d-PSB.html
Here are some more pictures of the injection pump:
Edited by TomMN - 03 Dec 2017 at 9:34pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 7:06am
control unit oring is a good source of fuel in the oil too.
